Sezione dedicata ai decoder EDISION Nino e NINO+ H.265
Nome: [IMAGE] OS Nino+ H.265 Nemoxyz SATtek CBGInterstellar v5.6 openATV v7.6 - Py3 branch OE5.6
Autore: Nemoxyz
Descrizione: https://i.gyazo.com/42feb638ee6a6b97abe0cd0d745a99f3.jpg
VERSIONE SOFTWARE & SORGENTE
OFFICIAL-IMAGE-SATtechnology: Ver1 - 20-NOVEMBRE-2025
MODELLO DECODER
Adatto ad un decoder Enigma2 EDISION OSNINO+ H265 ( CPU MIPS )
https://i.imgur.com/tCelhiV.png
FEATURES:
SCREENSHOTS DI PRESENTAZIONE:
https://i.gyazo.com/c6b6d43618b3f405fe41049d48392434.jpg
https://i.gyazo.com/90add43c768dbba6bd2fa8cc4c190436.jpg
https://i.gyazo.com/13a5c94610310165942db01114c1681e.jpg
https://i.gyazo.com/2987a9eefb69df874b254743b921dc7c.jpg
https://i.gyazo.com/4fbc050c76b2f70ec9f6218995f0035f.jpg
https://i.gyazo.com/688457c18c97ddff2bd70cdde0cd1886.jpg
https://i.gyazo.com/d267f346d6be8cdaa4f498cc7327037f.jpg
https://i.gyazo.com/b255f66c83b016649c262652e1bdbb99.jpg
https://i.gyazo.com/b565c48bfbed4bacf883aa6bb64b6a71.jpg
https://i.gyazo.com/b21f8266b045076738ca0de7d16ce914.jpg
https://i.gyazo.com/ec31b6666995e34a044c790c62f07d57.jpg
https://i.gyazo.com/3f4cbdf1368e5abf1c02dd378c23595e.jpg
https://i.gyazo.com/05c2a753034c090299ef2551524ce47d.jpg
https://i.gyazo.com/570bf65bdfada3d70de26190366b1812.jpg
https://i.gyazo.com/76e062bbcd13962a8ef3855f2f761eb6.jpg
https://i.gyazo.com/468cef20c51d8de36c86ccc68674285e.jpg
https://i.gyazo.com/ee8c44ad5dcfa9bfc86c06643e7545d0.jpg
https://i.gyazo.com/d92082ccd33bdd2d2c969ec738de94bb.jpg
INSTALLAZIONE
Eseguire il seguente comando:
- scegliete iSettingE2
HOTBIRD 13°E + DTT ITA:
ZpiconS [417x250] HB13° + DTT Nemoxyz DESIGN (19-Maggio-2026) - HD & FullHD skin [HiRes]
X(small)piconS [100x60] HB13° + DTT Nemoxyz DESIGN (19-Maggio-2024) [LowRes]
ASTRA 19.2°E:
ZpiconS [417x250] ASTRA 19.2° UPDATE (19 MAGGIO 2026) - HD & FullHD skin [HiRes]
X(small)piconS [100x60] ASTRA 19.2° UPDATE (19 MAGGIO 2026) [LowRes]
EUTELSAT 5°W + 9°E:
ZpiconS [417x250] 5W° + 9E° EUTELSAT Nemoxyz DESIGN (19-Maggio-2026) - HD & FullHD skin [HiRes]
X(small)piconS [100x60] 5W° + 9E° EUTELSAT Nemoxyz DESIGN (19-Maggio-2026) [LowRes]
ZpiconS [417x250] Rakuten-Pluto-SamsungTV Nemoxyz DESIGN (19-Maggio-2026) - HD & FullHD skin [HiRes]
X(small)piconS [100x60] Rakuten-Pluto-SamsungTV Nemoxyz DESIGN (19-Maggio-2026) [LowRes]
Versione: SATtekBUILD-Ver1 [20-11-2025]
File: SATtekCBGInterstellarATV-7.6.0-osninoplus-20251120_usb.zip
Dimensione: 160.87 MB
Vedi Download: [IMAGE] OS Nino+ H.265 Nemoxyz SATtek CBGInterstellar v5.6 openATV v7.6 - Py3 branch OE5.6
Modificato 4 volte da Nemoxyz 5 anni. Motivazione: Download Aggiornato
Ciao e scusa la mia ignoranza
ho scaricato la tua cartella dedicata per Nino Plus ma con estensione ipk non riesco a visualizzare niente
Devo poi fare un reset del decoder prima di inserire la chiavetta?
Capisco che sto diventando rompi... ma se tu avessi la pazienza di darmi una mano.....
@blueway siamo qui per questo !!! Dimmi un po cosa nn va e cosa non capisci , ti ho spostato sotto il topic di discussione dedicato al package. Ci sono le istruzioni da leggere le hai lette punto per punto ??
Buongiorno e grazie
Intanto non capisco perchè il decoder non mi rilevi i canali italiani poi come ti ho già scritto non so se devo fare un reset prima di inserire la chiavetta ,come devo fare per scompattare i file e quali inserire.
Ho letto più volte le istruzioni ma non ne vengo a capo.
Devo scaricare un programma per leggere file ipk?
Come faccio a veere se il decoder legge la scheda tivusat?
Grazie e buona giornata
@blueway buongiorno., lascia stare per ora la ricezione dei canali , vuoi fare un step successivo prima di fare quelli base. :party: Ti ho spostato sotto il package settings di cui stai tentando installazione per non confondere le discussioni.
Andiamo per gradi...
1) hai installato putty-telnet sul tuo pc ? hai installato un client FTP tipo filezilla o winSCP sul tuo pc ?
2) il decoder ha su la openATV 6.4 flashata ??
rispondi a queste domande e se non fatto esegui questi primi passi. dopodichè ci sta seguire questi STEPs scritti qui sopra in descrizione in prima pagine e che ti riporto quotando qui sotto ( non ti serve nessun software per legger IPK , IPK è estensione dei plugins e pacchetti engima2 vengono riconosciuti dal decoder non ti fare problemi dove non ci sono !! ) :
segui i passaggi se il decoder è appena flashato del wizard per assegnare poi una password di accesso ( menu impostazioni password ) ti servià per loggarti con telnet e con FTPcliente per inviare il file IPK che è dentro uno zip e dovrai scompattare
GIUNTI A QUESTO PUNTO AVRETE IL VOSTRO DECODER FLASHATO CON IL SOFTWARE BASE MA NON CONFIGURATO!!
ok ora ho installato puffy telnet e winscp
io avevo installato anno scorso su tue indicazioni open 6.4
@blueway in 1 anno ci sono grandi grandi differenze sulle images per cui devi scaricare ed installare la versione più recente per avere il decoder ben funzionante.
@Nemoxyz Sto provando questo decoder vorrei farci una recensione da portare sul mio canale ma la versione open atv di settembre è veramente instabile in piu non ho ben capito come far funzionare i servizi hbbtv ha qualche consiglio da darmi ?
@ILMASTRO85 quale versione di openATV ? perchè se hai provato una tipo 6.5 o 7.0 sconsiglio caldamente, openATV 6.4 è tutt'ora la "stable release"
@Nemoxyz 6.4 liscia ho solo installato la cam per fargli leggere la scheda tvsat e il **NOT-mention** per i setting ma per i servizi hbbtv bisogna instalalre qualcosa . ps grazie del tuo tempo
Mi tradisci con **NOT-mention** :-) ahaha si scherza... :laugh: abbiamo il nostro setting > blog/setting-e2-manutek/ da usare con isettingE2 di solito questo suggeriamo ai nostri user. Cmq è una cosa laterale ed un "pourparler" e non ci entra nulla...con il punto della discussione. i servizi hbbtv che io sappia, non sono ben digeriti dai decoder enigma2 che di fondo come ben saprai non hanno "omologazione" a nessuna di queste piattaforme e trasmissioni ibride. So che esiste nei fedds della openATV un plugin apposito per l' "hbbtv" ma non ti saprei anticipare l'esito positivo del suo utilizzo andrebbe testato. Di nulla per così poco! Siamo qui per questo ;)
@Nemoxyz chiedo venia non lo sapevo visto che pubblicizzo il sito sui miei link e nei miei video mi sembra anche giusto adottare il tuo plug in lo installo subito grazie per il tuo tempo
@ILMASTRO85 non ti devi fare problemi era solo una battuta scherzosa, certo mi fa piacere se utilizzi isettingE2 + nostro setting ( curato ed ideato direttamente da me )
Trovi il download del plugin isettingE2 nella versione mipsel per questo modello qui :
dlext/details?df_id=1030
