Moderatore: Content Writers
Cari amici benvenuti in questo Topic dove voglio raccontarvi la mia esperienza con uno box Android Tv con Tuner Dvb -T2
Di seguito Trovate una recensione completa e dettagliata su mio canale youtube.
Specifiche tecniche
-OS AndroidTV™ 10
-Processore Quad Core Cortex-A53
-Chip: Amlogic S905X2
-RAM: 2 GB
-Flash: 8 GB
-WiFi: WIFI5 2x2, Dual band (2.4GHz/5GHz), 2 antennas
-Bluetooth: BT 5.0
-DVB Tuner&Demod: DVB-T/T2 single tuner
-Power Button: Standby / Wake-up / Recovery menu
-1 Bicolor LED: Red/Green for Standby/Working mode respectively
-RF: input 1
-DC: input 1
-RJ45 Ports: 1x RJ45(10/100 BaseT)
-HDMI Ports: 1x HDMI 2.0b with CEC (HDCP 1.4/2.2)
-AV Ports: 1x 3.5mm miniAV port
-USB Ports: USB 2.0 Type A 500 mA max. HDD up to 5TB / USB pendrive up to 128GB
-AC input: 100V~240VAC 50/60Hz
-Power consumption: max Max Power: 18W
-Dimension: 148mm x 100mm x 31.5mm
-PSU: 1x EU: Wall plug 100-240VAC 12V 1.5A DC
-RCU: 47 Keys Bluetooth + Infrared combo RCU
-Push-to-talk: Dedicated button for Google Assistant voice control
-DRM Microsoft Playready 3, Google Widevine L1
-Audio codecs: Dolby Digital, Dolby Digital Plus, AAC, LC-AAC, HE-AAC, MP3
-Video codecs: MPEG2 L1-L2-L3, MPEG1 L2, H.264, H.265 / H.265 Main 10 Profile 5.1
-HDR: HLG, HDR10
-Streaming Protocols: HLS, MPEG-DASH
DVB features
-LCN: Support
-LCN: conflicts Support
-Teletext (TTX): DVB Teletext (EN 300 472 - EN 300 706)
-TTX and DVB subtitles: Support
-Audio Description: Support for receiver-mix and broadcaster-mix AD
-PSI/SI management: Support
-Event Information: Support for DVB
-EPG: Support DVB EPG
-A/V downscale / downmix: support for video downscale and audio downmix via AV out
-SW upgrade: via USB (ZIP file) Online (Google OTA)
-USB filesystem: FAT32 and NTFS
-Video Resolution: SCART: 576p (PAL) HDMI: up to 2160p@60Hz (H.265)
-Color Depth: Up to 10 bit
-PVR/Timeshift: no/no
-Parental control: Yes, Parental rating descriptor support, Age thresholds, Parental control on/off menu option
-Favorite channels: 10 liste canali favoriti
-Channel scan: Manuale and Automatico
-Channel upgrade: Rilevamento automatico dei nuovi canali trasmessi (Autoscan)
-Guida canali EPG DVB
-Informazione evento (evento in onda/successivo, descrizione breve/lunga)
-Televideo/Sottotitoli
-Power management: Normal and Deep (low power standby)
-Auto switch off: 3h for user inactivity (customizable from user side)
-Supported Countries: Italy, Germany, Sweden, Finland, Greece, Spain, Denmark, Czech Republic, Slovenia, Poland
-Factory reset: Support
Applications and Certification
-Android TV: Officially certified
-Store: Official Google Play Store with access to Play Store applications.
LINK DOWNLOAD APP
NETFLIX:https://tinyurl.com/4cesmnkz
NOW TV: https://tinyurl.com/wn2kz295
LINK PER L'ACQUISTO
EMAIL DEL COSTRUTTORE
Buongiorno Sig. Mantello,
abbiamo guardato con interesse il suo unboxing e la ringraziamo per aver parlato di UP T2 4K.
Ci spiace non averle potuto inviare un decoder in conto visione ma, come giustamente sottolineato da lei nel video, c’è ancora shortage di prodotto nel mercato e siamo stati impossibilitati in questo primo periodo, altrimenti avremmo potuto parlare in anticipo di alcuni dei “punti deboli” da lei notati. Li esamino quindi qui di seguito:
• Mancanza di un QR code alla pagina prodotto o al manuale.
Abbiamo messo il link http://www.telesystem.it/UPT24K nel paragrafo “Maggiori informazioni” della guida rapida all’interno della confezione, pensando fosse sufficiente per l’utente, ma accogliamo il suo suggerimento e cercheremo di rendere la cosa più visibile con una revisione degli artwork (magari proprio con un QR code nel packaging).
• Mancanza dell’app di Netflix.
Abbiamo cercato di far approvare il progetto a Netflix ma, per logiche che non ci competono, i decoder ibridi IP/DVB-T2 per ora non vengono accettati (e il fatto che UP sia certificato Google Android TV non influisce su questo).
Come da lei verificato, gli utenti hanno già trovato il modo di sopperire a tale mancanza con apk esterni pienamente funzionanti anche in 4K, ma si tratta di soluzioni non ufficiali che, come azienda, non possiamo certo pubblicizzare. Per questo motivo cercheremo ancora di ottenere la certificazione Netflix.
• Mancanza dell’app Now TV
Anche in questo caso, come può ben immaginare, saremmo stati felici di poter ospitare l’applicazione sul Play store del decoder, ma spetta a SKY Italia definire su quali dispositivi renderla disponibile.
Tuttavia, in alternativa all’installazione dell’apk esterno da lei suggerita nel video, gli utenti possono anche usare la funzione Chromecast built-in per fare il playback dei contenuti inviati dall’app NOW TV dello smartphone/tablet in Full HD 1080p, senza dover cercare ed installare l’apk di NOW TV sul decoder.
• Funzione di registrazione
Ha già spiegato perfettamente nel video il motivo per cui non abbiamo inserito tale funzione. Il compenso per copia privata da pagare per ogni dispositivo dotato di funzione di registrazione secondo D.M. 30 giugno 2020 avrebbe fatto lievitare il prezzo del prodotto e abbiamo preferito evitarlo. Andremo tuttavia ad aggiungere la funzione timeshift con un aggiornamento.
Spero che queste informazioni le siano state utili, qualora volesse magari integrarle nella descrizione al video o in altro modo.
Cordiali saluti
