OFFICIAL-IMAGE-SATtechnology: Ver1 - 14-06-2022
DISPOSITIVO
Adatto ad un decoder Enigma2 ZGEMMA H9 COMBO SE ( CPU ARM )
SATtekEleganceBLUE-7.0-zgemmah9combose-20220614_mmc.zip
SATtekEleganceBLUE-7.0-zgemmah9combose-20220614_recovery_emmc.zip
IMAGE FEATURES:
- SPINNER Technology POWER
- TASTO PORTAL - BLU QUICK LAUNCH MENU - PER AVERE ACCESSO RAPIDO A MOLTE FUNZIONI DEL SOFTWARE
LINK DONWLOAD ED INFO:
iSettingE2 OE2.x - NEW VER - v3.6.3r1 - ( 09 MAGGIO 2025 )
INSTALLAZIONE
- ATTENZIONE: Per i modelli di decoder che prevedono anche la versione "recovery_mmc" il files è un unico RAR al cui interno troverete i 2 zip originali di compilazione image ( mmc/usb + recovery_mmmc )
Eseguire il seguente comando:
wget -O - -q http://updates.mynonpublic.com/oea/feed | bashGuida MOUNT USB DEVICE & XpiconS ( SAT + DTT completi originali by Nemoxyz )
ZpiconS [417x250] HB13° + DTT Nemoxyz DESIGN (01-Novembre-2024) - HD & FullHD skin
[HiRes]X(small)piconS [100x60] HB13° + DTT Nemoxyz DESIGN (01-Novembre-2024)
[LowRes]ASTRA 19.2°E:
ZpiconS [417x250] ASTRA 19.2° UPDATE (04 NOVEMBRE 2024) - HD & FullHD skin
[HiRes]X(small)piconS [100x60] ASTRA 19.2° UPDATE (04 NOVEMBRE 2024)
[LowRes]EUTELSAT 5°W + 9°E:
ZpiconS [417x250] 5W° + 9E° EUTELSAT Nemoxyz DESIGN (06-Novembre-2024) - HD & FullHD skin
[HiRes]X(small)piconS [100x60] 5W° + 9E° EUTELSAT Nemoxyz DESIGN (06-Novembre-2024)
[LowRes]Versione: SATtekBUILD-Ver1 [14-06-2022]
Vedi Download: [IMAGE] ZGEMMA H9 COMBO SE Nemoxyz SATtek Elegance BLUE v7.0 - Py3 branch OE5.0
