Sezione dedicata ai decoder Hitube 4K Combo
https://i.imgur.com/HlGjc97.png
VERSIONE SOFTWARE & SORGENTE
OFFICIAL-IMAGE-SATtechnology: Ver1 - 16-06-2022
DISPOSITIVO
Adatto ad un decoder Enigma2 HITUBE 4K PLUS ( CPU ARM)
https://i.imgur.com/qdHyPXB.png
SATtek E l e g a n c e ---- BLUE v 7 . 0 Py3
https://i.imgur.com/2h8kSzh.png
"Difficult to reach..Elegance is not for Everyone..."
SATtekEleganceBLUE-7.0-hitube4kplus-20220616_usb.zip
IMAGE FEATURES:
- SPINNER Technology POWER
- TASTO PORTAL - BLU QUICK LAUNCH MENU - PER AVERE ACCESSO RAPIDO A MOLTE FUNZIONI DEL SOFTWARE
LINK DONWLOAD ED INFO:
SCREENSHOTS DI PRESENTAZIONE SATtek Elegance BLUE v7.0 OEAlliance:
INSTALLAZIONE
Eseguire il seguente comando:
HOTBIRD 13°E + DTT ITA:
[HiRes]
[LowRes]
ASTRA 19.2°E:
[HiRes]
[LowRes]
EUTELSAT 5°W + 9°E:
[HiRes]
[LowRes]
Versione: SATtekBUILD-Ver1 [16-06-2022]
Vedi Download: [IMAGE] HITUBE 4K PLUS Nemoxyz SATtek Elegance BLUE v7.0 - Py3 branch OE5.0
Modificato 3 volte da Nemoxyz 4 anni. Motivazione: Le informazioni sono state aggiornate
