Sezione dedicata ai decoder ATEMIO 6200 HD (combo tuner: sat e dtt)
https://i.imgur.com/HlGjc97.png
VERSIONE SOFTWARE & SORGENTE
OFFICIAL-IMAGE-SATtechnology: Ver1 - 20-06-2022
DISPOSITIVO
Adatto ad un decoder Enigma2 ATEMIO 6200 HD ( CPU MIPS )
https://i.imgur.com/yO4j4VP.png
SATtek E l e g a n c e ---- BLUE v 7 . 0 Py3
https://i.imgur.com/2h8kSzh.png
"Difficult to reach..Elegance is not for Everyone..."
SATtekEleganceBLUE-7.0-atemio6200-20220620_usb.zip
IMAGE FEATURES:
- SPINNER Technology POWER
- TASTO PORTAL - BLU QUICK LAUNCH MENU - PER AVERE ACCESSO RAPIDO A MOLTE FUNZIONI DEL SOFTWARE
LINK DONWLOAD ED INFO:
SCREENSHOTS DI PRESENTAZIONE SATtek Elegance BLUE v7.0 OEAlliance:
INSTALLAZIONE
Eseguire il seguente comando:
HOTBIRD 13°E + DTT ITA:
[HiRes]
[LowRes]
ASTRA 19.2°E:
[HiRes]
[LowRes]
EUTELSAT 5°W + 9°E:
[HiRes]
[LowRes]
Versione: SATtekBUILD-Ver1 [20-06-2022]
UNA NOTA IMPORTANTE CHE PRECISIAMO FORTEMENTE:<br>E’ VIETATO QUALUNQUE USO DEI FILE DA NOI PRODOTTI A SCOPI NON REGOLAMENTARI! E' SEMPLICEMENTE UN BACKUP SOFTWARE E/O LISTA CANALI E QUESTA RIMANE TALE! CI ASTENIAMO DA OGNI RESPONSABILITA’ QUALUNQUE RIPRODUZIONE DELLA DESCRIZIONE CREATA DA SAT.TECHNOLOGY E’ ASSOLUTAMENTE VIETATA SE NON TRAMITE PREVIA RICHIESTA ED AUTORIZZAZIONE DA PARTE NOSTRA!
Vedi Download: [IMAGE] ATEMIO 6200 HD Nemoxyz SATtek Elegance BLUE v7.0 - Py3 branch OE5.0
Modificato 1 volta da Nemoxyz 4 anni. Motivazione: Le informazioni sono state aggiornate
