Sezione dedicata ai decoder Dinobot 4K Enigma2 + Android
https://i.imgur.com/HlGjc97.png
VERSIONE SOFTWARE & SORGENTE
OFFICIAL-IMAGE-SATtechnology: Ver1 - 22-06-2022
DISPOSITIVO
Adatto ad un decoder Enigma2 DINOBOT 4K ( CPU ARM )
https://i.imgur.com/E6ytEar.png
SATtek E l e g a n c e ---- BLUE v 7 . 0 Py3
https://i.imgur.com/2h8kSzh.png
"Difficult to reach..Elegance is not for Everyone..."
SATtekEleganceBLUE-7.0-dinobot4k-20220622_mmc.zip
IMAGE FEATURES:
- SPINNER Technology POWER
LINK DONWLOAD ED INFO:
SCREENSHOTS DI PRESENTAZIONE SATtek Elegance BLUE v7.0 OEAlliance:
INSTALLAZIONE
Eseguire il seguente comando:
HOTBIRD 13°E + DTT ITA:
ZpiconS [417x250] HB13° + DTT Nemoxyz DESIGN (01-Novembre-2024) - HD & FullHD skin
[HiRes]
X(small)piconS [100x60] HB13° + DTT Nemoxyz DESIGN (01-Novembre-2024)
[LowRes]
ASTRA 19.2°E:
ZpiconS [417x250] ASTRA 19.2° UPDATE (04 NOVEMBRE 2024) - HD & FullHD skin
[HiRes]
X(small)piconS [100x60] ASTRA 19.2° UPDATE (04 NOVEMBRE 2024)
[LowRes]
EUTELSAT 5°W + 9°E:
ZpiconS [417x250] 5W° + 9E° EUTELSAT Nemoxyz DESIGN (06-Novembre-2024) - HD & FullHD skin
[HiRes]
X(small)piconS [100x60] 5W° + 9E° EUTELSAT Nemoxyz DESIGN (06-Novembre-2024)
[LowRes]
Versione: SATtekBUILD-Ver1 [22-06-2022]
Vedi Download: [IMAGE] DINOBOT 4K Nemoxyz SATtek Elegance BLUE v7.0 - Py3 branch OE5.0
