Sezione dedicata ai decoder GigaBlue UHD QUAD 4K
https://i.imgur.com/HlGjc97.png
VERSIONE SOFTWARE & SORGENTE
OFFICIAL-IMAGE-SATtechnology: Ver1 - 29-06-2022
DISPOSITIVO
Adatto ad un decoder Enigma2 GIGABLUE QUAD 4K ( CPU ARM )
https://i.imgur.com/Kpe3avO.png
SATtek E l e g a n c e ---- BLUE v 7 . 0 Py3
https://i.imgur.com/2h8kSzh.png
"Difficult to reach..Elegance is not for Everyone..."
SATtekEleganceBLUE-7.0-gbquad4k-20220629_usb.zip
IMAGE FEATURES:
- SPINNER Technology POWER
LINK DONWLOAD ED INFO:
SCREENSHOTS DI PRESENTAZIONE SATtek Elegance BLUE v7.0 OEAlliance:
INSTALLAZIONE
Eseguire il seguente comando:
HOTBIRD 13°E + DTT ITA:
[HiRes]
[LowRes]
ASTRA 19.2°E:
[HiRes]
[LowRes]
EUTELSAT 5°W + 9°E:
[HiRes]
[LowRes]
Versione: SATtekBUILD-Ver1 [29-06-2022]
Vedi Download: [IMAGE] GIGABLUE QUAD 4K Nemoxyz SATtek Elegance BLUE v7.0 - Py3 branch OE5.0
