OFFICIAL-IMAGE-SATtechnology: Ver1 - 07-07-2022
DISPOSITIVO
Adatto ad un decoder Enigma2 Xtrend ET4X00 ( CPU MIPS )
SATtekEleganceBLUE-7.0-et4x00-20220707_usb.zip
IMAGE FEATURES:
- SPINNER Technology POWER
LINK DONWLOAD ED INFO:
INSTALLAZIONE
Eseguire il seguente comando:
wget -O - -q http://updates.mynonpublic.com/oea/feed | bashGuida MOUNT USB DEVICE & XpiconS ( SAT + DTT completi originali by Nemoxyz )
ZpiconS [417x250] HB13° + DTT Nemoxyz DESIGN (01-Novembre-2024) - HD & FullHD skin
[HiRes]X(small)piconS [100x60] HB13° + DTT Nemoxyz DESIGN (01-Novembre-2024)
[LowRes]ASTRA 19.2°E:
ZpiconS [417x250] ASTRA 19.2° UPDATE (04 NOVEMBRE 2024) - HD & FullHD skin
[HiRes]X(small)piconS [100x60] ASTRA 19.2° UPDATE (04 NOVEMBRE 2024)
[LowRes]EUTELSAT 5°W + 9°E:
ZpiconS [417x250] 5W° + 9E° EUTELSAT Nemoxyz DESIGN (06-Novembre-2024) - HD & FullHD skin
[HiRes]X(small)piconS [100x60] 5W° + 9E° EUTELSAT Nemoxyz DESIGN (06-Novembre-2024)
[LowRes]Versione: SATtekBUILD-Ver1 [07-07-2022]
Vedi Download: [IMAGE] XTREND ET4X00 Nemoxyz SATtek Elegance BLUE v7.0 - Py3 branch OE5.0
- ✅ PROVA AMAZON PRIME iscrizione gratuita 30gg per tanti contenuti Video e spedizioni rapide 🌐
- ✅ GamsGo Accounts DAZN ⚽️🏀🏈⚾️🎾🏐 Marketplace 🌐
