Sezione dedicata ai decoder Vu+Solo SE V2 modelli originali VU+
https://i.imgur.com/HlGjc97.png
VERSIONE SOFTWARE & SORGENTE
OFFICIAL-IMAGE-SATtechnology: Ver1 - 08-07-2022
DISPOSITIVO
Adatto ad un decoder Enigma2 VU+ SOLO SE ( CPU MIPS )
https://i.imgur.com/kEDL896.png
SATtek E l e g a n c e ---- BLUE v 7 . 0 Py3
https://i.imgur.com/2h8kSzh.png
"Difficult to reach..Elegance is not for Everyone..."
SATtekEleganceBLUE-7.0-vusolose-20220708_usb.zip
IMAGE FEATURES:
- SPINNER Technology POWER
LINK DONWLOAD ED INFO:
SCREENSHOTS DI PRESENTAZIONE SATtek Elegance BLUE v7.0 OEAlliance:
INSTALLAZIONE
Eseguire il seguente comando:
HOTBIRD 13°E + DTT ITA:
[HiRes]
[LowRes]
ASTRA 19.2°E:
[HiRes]
[LowRes]
EUTELSAT 5°W + 9°E:
[HiRes]
[LowRes]
Versione: SATtekBUILD-Ver1 [08-07-2022]
Vedi Download: [IMAGE] VU+ SOLO SE Nemoxyz SATtek Elegance BLUE v7.0 - Py3 branch OE5.0
