Sezione dedicata al modello AZBOX HD
[GUIDA] RECUPERO AZBOX PREMIUM HD IN BOOTING
Metodo usato per resuscitare azbox in booting causato da mancata corrente durante caricamento fw enigma2 come detto grazie alle guide di Cus2k, Gorski ,Tritus ,Raskyno
ho messo anche il fw openatv 6.3 funzionante
GUIDA
( così come la trovate anche all'interno del file zip scaricabile dal LINK fondo al post )
quando hai collegato il cavo di rete ,la jatg, avviato il putty, e il TFTP (mi raccomando eseguire procedura recupera azbox per i settaggi e sia per jatg che per server TFTP ),
accendi azbox e vedrai questo :
xosPe0 serial#9b5791f03643749998c43e1124711c5b subid 0x50
xenv cs2 ok
xenv cs2 ok
power supply: ok
dram0 ok (8)
dram1 ok (9)
zboot (0) ok
* SMP863x zboot start ...
* Version: 2.4.0-2.8.0.1
* Started at 0x91000000.
* Configurations (chip revision: 6):
*    Use 8KB DRAM as stack.
*    Support XLoad format.
*    Enabled BIST mode.
*    Enabled memory test mode.
*    Use internal memory for stage0/1.
Boot from flash (0x48000000) mapped to 0x8c000000.
Found XENV block at 0x8c000000.
CPU clock frequency: 300.37MHz.
System clock frequency: 200.25MHz.
DRAM0 dunit_cfg/delay0_ctrl (0xf34111ba/0x000a8887).
DRAM1 dunit_cfg/delay0_ctrl (0xf34111ba/0x000a7787).
Using UART port 0 as console.
Board ID.: "852-E2"
Chip Revision: 0x8634:0x86 .. Matched.
Setting up H/W from XENV block at 0x8c000000.
  Setting <SYSCLK avclk_mux> to 0x00000000.
  Setting <SYSCLK hostclk_mux> to 0x00000100.
  Setting <IRQ rise edge trigger lo> to 0xff28ca00.
  Setting <IRQ fall edge trigger lo> to 0x0000c000.
  Setting <IRQ rise edge trigger hi> to 0x0000009f.
  Setting <IRQ fall edge trigger hi> to 0x00000000.
  Setting <IRQ GPIO map> to 0x20090820.
  Setting <PB default timing> to 0x10101010.
  Setting <PB timing0> to 0x10101010.
  Setting <PB Use timing0> to 0x000003f4.
  Setting <PB timing1> to 0x00110101.
  Setting <PB Use timing1> to 0x000003f3.
  Setting <PB timing2> to 0x105f1010.
  Setting <PB Use timing2> to 0x000003f8.
  PB cs config: 0x000e0040 (use 0x000e0040)
  Enabled Devices: 0x00021ace
    BM/IDE PCIHost Ethernet I2CM I2CS USB PCIDev2 PCIDev3 SCARD
  MAC: 00:02:14:15:51:73
  PCI IRQ routing:
    IDSEL 2: INTA(#14) INTB(#14) INTC(#14) INTD(#14)
    IDSEL 3: INTA(#15) INTB(#15) INTC(#15) INTD(#15)
  Smartcard pin assignments:
    OFF pin = 0
    5V pin = 1
    CMD pin = 2
  Setting up Clean Divider 2 to 96000000Hz.
  Setting up Clean Divider 4 to 33333333Hz.
  Setting up Clean Divider 5 to 25000000Hz.
  Setting up Clean Divider 6 to 20000000Hz.
  Setting up Clean Divider 7 to 20000000Hz.
  GPIO dir/data = 0x76000038/0x76000000
  UART0 GPIO mode/dir/data = 0x6e/0x00/0x00
  UART1 GPIO mode/dir/data = 0x6e/0x00/0x00
XENV block processing completed.
Found existing memcfg: DRAM0(0x08000000), DRAM1(0x08000000)
Heap/Temp/Temp1/Dest start at 0x14000000/0x16000000/0x15000000/0x12000000.
Default boot index: 0
Scanning ROMFS image at 0x8c040000 (0x48040000) .. Found.
ROMFS found at 0x8c040000, Volume name = YAMON_XRPC
Found 1 file(s) to be processed in ROMFS.
Processing xrpc_xload_yamon_ES4_prod.bin (start: 0x8c040090, size: 0x0002fe84)
  Checking zboot file signature .. Not found.
  Trying xrpc_xload format .. OK
  Checking zboot file signature at 0x13000000 .. OK
  Decompressing to 0x91200000 .. OK (453328/0x6ead0).
  Load time total 173/255 msec.
Execute final at 0x91200000 ..
* YAMON ROM Monitor
* Revision 02.06-SIGMADESIGNS-01-2.8.0.1
Memory:  code: 0x11000000-0x11040000, 0x11200000-0x11204000
reserved data: 0x11240000-0x12440000, PCI memory: 0x12440000-0x12840000
Environment variable 'start' exists. After 1 seconds
it will be interpreted as a YAMON command and executed.
Press Ctrl-C (or do BREAK) to bypass this.
xrpc failed (9)--- if a xtask is using a cipher or if you reboot
            --- xrpc will fail with RM_BUSY
  Checking zboot signature..  it's not zboot file.
Error : Internal, code = ffffffff
YAMON>
ora una volta che avrai yamon mettere i parametri una lla volta e attendere esisto positivo
setenv bootserver 192.168.1.5 (IP address of your computer)
setxenv y.gateway "192.168.xxx.xxx"   gateway della tua rete
setxenv y.subnetmask "255.255.255.0" Eure Subnet mask
setxenv y.ipaddr "192.168.xxx.xxx"   mettere un indirizzo a caso partendo da quello che hai con il tuo pc
net init                              Initialisiert das Netzwerk
---------------------------------quello che vedrete su putty----------------------
YAMON> setxenv y.gateway "mettete IP gateway"
Original value: "192.168.xxx.xxx", New value: "192.168.xxx.xxx"
Updating XENV block at 0x48000000.
YAMON> setxenv y.subnetmask "255.255.255.0"
Original value: "255.255.255.0", New value: "255.255.255.0"
XENV verification OK.
YAMON> setxenv y.ipaddr "mettete IP azbox"
YAMON> net init
Ethernet driver for EM86XX (v1.0)
(MAC 00:02:14:15:51:73, tx_desc/rx_desc = 16/32)
em86xx_eth::open(em86xx_eth) - Full-duplex mode
em86xx_eth::open(em86xx_eth) - 100 Mbit/s
em86xx_eth ethernet start
ipaddr:     192.168.xxx.xxx
subnetmask: 255.255.255.0
gateway:    192.168.xxx.xxx
YAMON>
ora bisogna dare all'AZ l'istruzione per caricare il file di backup che il software TFTP server è pronto ad inviargli (ilk programma era connesso dall'inizio della procedura) ----mi raccomando seguire file pdf recupera azbox  server tftp ----
load -b tftp://192.168.xxx.xxx/backup_kernel 0xb0100000   ----mettere indirizzo del tuo pc
attendere fino a che non rivediamo il YAMON>
diamo il comando
pflash write -f 0x80000 0xb0100000 0x680000
ora inizia la procedura di "erasing" e di "writing" , dopo circa 5 minuti il vostro az sarà stato rispristinato
ora nel mio caso al rivvio non riconosceva usb e rete ecc.. allora ho eseguito questo altro passaggio
rieseguito le stesse inizializzazioni fatte precedenti :
YAMON>
1) setenv bootserver 192.168.xxx.xxx (IP address of your computer)
YAMON>
2) setxenv y.gateway "192.168.xxx.xxx"   gateway della tua rete
YAMON>
3)setxenv y.subnetmask "255.255.255.0" Eure Subnet mask
YAMON>
4)setxenv y.ipaddr "192.168.xxx.xxx"   mettere un indirizzo a caso partendo da quello che hai con il tuo pc
YAMON>
5)net init                              Initialisiert das Netzwerk
YAMON>
6) net up                                (gets up network interface)
YAMON>
7)load -b tftp://192.168.xxx.xxx/vmlinux.bin 0x90020000     --- mettere indirizzo del tuo pc
YAMON>
9)go
 YAMON>
A questo punto scorrendo sopra la finestra putty troverete indirizzo ip del decoder e il gioco e fatto
da qui caricare fw tramite azup io ho usato 2.2.7 mettete indirizzo e connette e caricate la pach.e2 che stavate utilizzando alla fine scollegate tutto e avrete il dec recuperato
RINGRAZIAMENTI: questi sono i passaggi presi dall'amico Cus2K e Gorski
LINK DOWNLOAD GUIDA: procedura recupero booting azbox
Si lo scaricato qualche anno fa proprio perche gi[…]
