Sezione dedicata ai decoder AXAS E4HD 4K ULTRA HD
https://i.imgur.com/HlGjc97.png
VERSIONE SOFTWARE & SORGENTE
OFFICIAL-IMAGE-SATtechnology: Ver1 - 21-09-2022
DISPOSITIVO
Adatto ad un decoder Enigma2 AXAS E4HD 4K ULTRA ( CPU ARM )
https://i.imgur.com/PDuawlb.png
SATtek E l e g a n c e ---- BLUE v 7 . 0 Py3
https://i.imgur.com/2h8kSzh.png
"Difficult to reach..Elegance is not for Everyone..."
SATtekEleganceBLUE-7.0-e4hdultra-20220921_usb.zip
SATtekEleganceBLUE-7.0-e4hdultra-20220921_recovery_emmc.zip
IMAGE FEATURES:
- SPINNER Technology POWER
- TASTO PORTAL CONFIGURATO PER AVERE ACCESSO RAPIDO A MOLTE FUNZIONI DEL SOFTWARE
( https://sat.technology/viewtopic.php?f=89&t=32006 )
LINK DONWLOAD ED INFO:
SCREENSHOTS DI PRESENTAZIONE SATtek Elegance BLUE v7.0 OEAlliance:
INSTALLAZIONE
- ATTENZIONE: Per i modelli di decoder che prevedono anche la versione "recovery_mmc" il files è un unico RAR al cui interno troverete i 2 zip originali di compilazione image ( mmc/usb + recovery_mmmc )
Eseguire il seguente comando:
HOTBIRD 13°E + DTT ITA:
ZpiconS [417x250] HB13° + DTT Nemoxyz DESIGN (01-Novembre-2024) - HD & FullHD skin
[HiRes]
X(small)piconS [100x60] HB13° + DTT Nemoxyz DESIGN (01-Novembre-2024)
[LowRes]
ASTRA 19.2°E:
ZpiconS [417x250] ASTRA 19.2° UPDATE (04 NOVEMBRE 2024) - HD & FullHD skin
[HiRes]
X(small)piconS [100x60] ASTRA 19.2° UPDATE (04 NOVEMBRE 2024)
[LowRes]
EUTELSAT 5°W + 9°E:
ZpiconS [417x250] 5W° + 9E° EUTELSAT Nemoxyz DESIGN (06-Novembre-2024) - HD & FullHD skin
[HiRes]
X(small)piconS [100x60] 5W° + 9E° EUTELSAT Nemoxyz DESIGN (06-Novembre-2024)
[LowRes]
Versione: SATtekBUILD-Ver1 [21-09-2022]
Vedi Download: [IMAGE] AXAS E4HD 4K ULTRA Nemoxyz SATtek Elegance BLUE v7.0 - Py3 branch OE5.0
Hello Nemoxyz!
I wanted to report a bug. In the tuner configuration, port B cannot be changed when DiseqC A / B is set. I cannot select a satellite other than Hotbird. Are you able to improve it?
On Vu+ Duo 4k SE is OK. On Axas E4HD Ultra only Hotbird or automatic.
@angostura Hello good evening. Due a little mistake on the past job compilation ( this one is dated on 21-09-2022 ) there was a "satellite.xml" mono file added not wanted and not useful in the folder /etc/enigma2/ so remove it , install a dual feed setting if not yet done, reboot the decoder and try again, will fix it . As soon as possible I will re-compile also this AXAS E4HD 4K ULTRA with the new recipes as I'v done with Vu+ some days ago
