Sezione dedicata ai decoder Zgemma H11 series ( H11S )
Nome: [IMAGE] ZGEMMA H11S (UHD-4K) Nemoxyz SATtek CBGInterstellar v5.6 openATV v7.6 - Py3 branch OE5.6
Autore: Nemoxyz
Descrizione: https://i.gyazo.com/42feb638ee6a6b97abe0cd0d745a99f3.jpg
VERSIONE SOFTWARE & SORGENTE
OFFICIAL-IMAGE-SATtechnology: Ver1 - 21-NOVEMBRE-2025
MODELLO DECODER
Adatto ad un decoder Enigma2 ZGEMMA H11S ( CPU ARM )
https://i.imgur.com/RupSDkG.png
FEATURES:
SCREENSHOTS DI PRESENTAZIONE:
https://i.gyazo.com/c6b6d43618b3f405fe41049d48392434.jpg
https://i.gyazo.com/90add43c768dbba6bd2fa8cc4c190436.jpg
https://i.gyazo.com/13a5c94610310165942db01114c1681e.jpg
https://i.gyazo.com/2987a9eefb69df874b254743b921dc7c.jpg
https://i.gyazo.com/4fbc050c76b2f70ec9f6218995f0035f.jpg
https://i.gyazo.com/688457c18c97ddff2bd70cdde0cd1886.jpg
https://i.gyazo.com/d267f346d6be8cdaa4f498cc7327037f.jpg
https://i.gyazo.com/b255f66c83b016649c262652e1bdbb99.jpg
https://i.gyazo.com/b565c48bfbed4bacf883aa6bb64b6a71.jpg
https://i.gyazo.com/b21f8266b045076738ca0de7d16ce914.jpg
https://i.gyazo.com/ec31b6666995e34a044c790c62f07d57.jpg
https://i.gyazo.com/3f4cbdf1368e5abf1c02dd378c23595e.jpg
https://i.gyazo.com/05c2a753034c090299ef2551524ce47d.jpg
https://i.gyazo.com/570bf65bdfada3d70de26190366b1812.jpg
https://i.gyazo.com/76e062bbcd13962a8ef3855f2f761eb6.jpg
https://i.gyazo.com/468cef20c51d8de36c86ccc68674285e.jpg
https://i.gyazo.com/ee8c44ad5dcfa9bfc86c06643e7545d0.jpg
https://i.gyazo.com/d92082ccd33bdd2d2c969ec738de94bb.jpg
INSTALLAZIONE
Eseguire il seguente comando:
- scegliete iSettingE2
HOTBIRD 13°E + DTT ITA:
ZpiconS [417x250] HB13° + DTT Nemoxyz DESIGN (01-Novembre-2024) - HD & FullHD skin [HiRes]
X(small)piconS [100x60] HB13° + DTT Nemoxyz DESIGN (01-Novembre-2024) [LowRes]
ASTRA 19.2°E:
ZpiconS [417x250] ASTRA 19.2° UPDATE (04 NOVEMBRE 2024) - HD & FullHD skin [HiRes]
X(small)piconS [100x60] ASTRA 19.2° UPDATE (04 NOVEMBRE 2024) [LowRes]
EUTELSAT 5°W + 9°E:
ZpiconS [417x250] 5W° + 9E° EUTELSAT Nemoxyz DESIGN (06-Novembre-2024) - HD & FullHD skin [HiRes]
X(small)piconS [100x60] 5W° + 9E° EUTELSAT Nemoxyz DESIGN (06-Novembre-2024) [LowRes]
ZpiconS [417x250] Rakuten-Pluto-SamsungTV Nemoxyz DESIGN (20-Luglio) - HD & FullHD skin [HiRes]
X(small)piconS [100x60] Rakuten-Pluto-SamsungTV Nemoxyz DESIGN (20-Luglio) [LowRes]
Versione: SATtekBUILD-Ver1 [21-11-2025]
File: SATtekCBGInterstellarATV-7.6.0-zgemmah11s-20251121.rar
Dimensione: 159.67 MB
Vedi Download: [IMAGE] ZGEMMA H11S (UHD-4K) Nemoxyz SATtek CBGInterstellar v5.6 openATV v7.6 - Py3 branch OE5.6
Modificato 6 volte da Nemoxyz 3 anni. Motivazione: Download Aggiornato
Buondi, SOS. Mi è arrivato lo Zetahemma H11, Settato con questa : [PCKGSETTINGS] ZGEMMA H11SERIES (UHD-4K) NEMOXYZ OPENATV 7.X (7.3) PY3 OE2.9 CBGC INTERSTELLAR V4.1. All'avvio 7/8 volte cerchio che gira e poi inchiodato sullo sfondo della Vs immagine. Come ne esco fuori? gia avviato 3 volte e stesso risultato. Attendo con ansia tue. Grazie
@elia57 buogiorno, dovresti scrivere sempre sotto il topic ufficiale del download cui fai riferimento, altrimenti se scrivete dove vi pare si fa un guazzabuglio medioevale da malditesta ed è difficile potervi aiutare. Vediamo di essere più precisi...ok ? :party:
Ti ho spostato io per questa volta, grazie per l'attenzione.
Venendo a noi ed il problema che stai avendo, dovresti reinstallare la openATV 7.3 da base fai il wizard iniziale , setta i tuners per l'utilizzo e sintonizzazione e poi prima di mandare il package IPK mandami il file "settings" ( che trovi dentro /etc/enigma2 ) zippato e lo alleghi qui, così lo analizzo e vediamo di capire come va impostato nello specifico per il package e cosa non gli piace attualmente tanto da mandare in loop il sistema operativo.
Qui sorge il problema, come la installo la openATV 7.? Ho provato a metterla su pennetta quella con estensione emmc, ma all'avvio va direttamente sulla Intestellar. L'unica cosa positiva che dcon Winspc e Putty ci entro dentro.
Ha scritto dopo 12 minuti 14 secondi:
Sono riuscito ad instalare immagine dal web Grazie.
@elia57 ma scusami come hai installato la prima volta la ATV 7.3 ? nello stesso modo la reinstalli...
Si certo non è bloccato il decoder va in loop perchè probabilmente qualche impostazione del package non gli piace e si riavvia.
Allora la recovery_emmc serve per ripristinare il decoder cancellando tutto e poi ci devi mandare la multi
oppure puoi seguire questa via seguimi senza reinstallare nulla:
da telnet-putty digita :
init 4
poi preleva il file in allegato , scompattalo e lo metti in /etc/enigma2/ ( sovrascrivendolo)
a questo punto da telnet putty dai comando di riavvio e vediamo come va
reboot
elia57 ha scritto: 2 anni Sono riuscito ad instalare immagine dal web Grazie.
Eh niente potevamo nel modo in cui ti dicevo vedere se era quello il problema...ok allora torniamo alla prima opzione.
Ha scritto dopo 3 minuti 35 secondi:
NB: penso di aver capito dove sta il problema , l' H11 è un H11S giusto ? è equipaggiato con solo 1 tuner SAT dico bene ? il package gli impone (per errore ) la presenza anche del combo DVB-T tuner DTT per cui non trovandolo va in panne...al 99% è questo il problema.
@elia57 figurati è un piacere, se mi mandi file "settings" come detto facciamo chiarezza e posso modificare il package in modo che sia perfettamente funzionante.
