Sezione dedicata ai decoder PULSe 4K modelli ABcom
Nome: [IMAGE] ABcom PULSe 4K Nemoxyz SATtek CBGInterstellar v5.6 openATV v7.6 - Py3 branch OE5.6
Autore: Nemoxyz
Descrizione: https://i.gyazo.com/42feb638ee6a6b97abe0cd0d745a99f3.jpg
VERSIONE SOFTWARE & SORGENTE
OFFICIAL-IMAGE-SATtechnology: Ver1 - 02-NOVEMBRE-2025
MODELLO DECODER
Adatto ad un decoder Enigma2 ABcom PULSe 4K ( CPU ARM )
https://i.imgur.com/ern4rzU.png
FEATURES:
SCREENSHOTS DI PRESENTAZIONE:
https://i.gyazo.com/c6b6d43618b3f405fe41049d48392434.jpg
https://i.gyazo.com/90add43c768dbba6bd2fa8cc4c190436.jpg
https://i.gyazo.com/13a5c94610310165942db01114c1681e.jpg
https://i.gyazo.com/2987a9eefb69df874b254743b921dc7c.jpg
https://i.gyazo.com/4fbc050c76b2f70ec9f6218995f0035f.jpg
https://i.gyazo.com/688457c18c97ddff2bd70cdde0cd1886.jpg
https://i.gyazo.com/d267f346d6be8cdaa4f498cc7327037f.jpg
https://i.gyazo.com/b255f66c83b016649c262652e1bdbb99.jpg
https://i.gyazo.com/b565c48bfbed4bacf883aa6bb64b6a71.jpg
https://i.gyazo.com/b21f8266b045076738ca0de7d16ce914.jpg
https://i.gyazo.com/ec31b6666995e34a044c790c62f07d57.jpg
https://i.gyazo.com/3f4cbdf1368e5abf1c02dd378c23595e.jpg
https://i.gyazo.com/05c2a753034c090299ef2551524ce47d.jpg
https://i.gyazo.com/570bf65bdfada3d70de26190366b1812.jpg
https://i.gyazo.com/76e062bbcd13962a8ef3855f2f761eb6.jpg
https://i.gyazo.com/468cef20c51d8de36c86ccc68674285e.jpg
https://i.gyazo.com/ee8c44ad5dcfa9bfc86c06643e7545d0.jpg
https://i.gyazo.com/d92082ccd33bdd2d2c969ec738de94bb.jpg
INSTALLAZIONE
Eseguire il seguente comando:
- scegliete iSettingE2
HOTBIRD 13°E + DTT ITA:
ZpiconS [417x250] HB13° + DTT Nemoxyz DESIGN (19-Maggio-2026) - HD & FullHD skin [HiRes]
X(small)piconS [100x60] HB13° + DTT Nemoxyz DESIGN (19-Maggio-2024) [LowRes]
ASTRA 19.2°E:
ZpiconS [417x250] ASTRA 19.2° UPDATE (19 MAGGIO 2026) - HD & FullHD skin [HiRes]
X(small)piconS [100x60] ASTRA 19.2° UPDATE (19 MAGGIO 2026) [LowRes]
EUTELSAT 5°W + 9°E:
ZpiconS [417x250] 5W° + 9E° EUTELSAT Nemoxyz DESIGN (19-Maggio-2026) - HD & FullHD skin [HiRes]
X(small)piconS [100x60] 5W° + 9E° EUTELSAT Nemoxyz DESIGN (19-Maggio-2026) [LowRes]
ZpiconS [417x250] Rakuten-Pluto-SamsungTV Nemoxyz DESIGN (19-Maggio-2026) - HD & FullHD skin [HiRes]
X(small)piconS [100x60] Rakuten-Pluto-SamsungTV Nemoxyz DESIGN (19-Maggio-2026) [LowRes]
Versione: SATtekBUILD-Ver1 [03-11-2025]
File: SATtekCBGInterstellarATV-7.6.0-pulse4k-20251103.rar
Dimensione: 149.73 MB
Vedi Download: [IMAGE] ABcom PULSe 4K Nemoxyz SATtek CBGInterstellar v5.6 openATV v7.6 - Py3 branch OE5.6
Modificato 5 volte da Nemoxyz 2 anni. Motivazione: Download Aggiornato
ok vorrei istallare l interstellar... ...ho scaricato l immagine base....openatv 7.3 ho trovato 2 file... unforce_pulse4k e una cartella pulse4k... che faccio?
si quello l ho visto... ho provato a scaricare la 7.3 base... ma non trovo i 3 file come da spiegazione... trovo "unforce_pulse4k" e una cartella "pulse4k"... sono quei 2 file da caricare sulla pennetta? inoltre avendo il multiboot... dove lo carico?bisogna scegliere prima lo slot di istallazione?
@gippo visto che l'argomento verte sull'installazione del package è necessario scrivere sotto il topic ufficiale di quell'argomento. Spostato...lì !! :party:
Qui trovi i download della image base : LINK
Dentro trovi i files necessari e sufficienti , la guida al flash è generica , installa la image come fai di solito, metti la cartella decompressa su pennetta usb e flasha non ti preoccupare.
Successivamente seguendo le istruzioni scritte qui sopra potrai installare il package interstellar.
Se vuoi installlare in multiboot è necessario in quel caso se parti da una image già presente usare il tool di gestione muliboot della image stessa e scegliere lo zip della openATV 7.3 scaricata o direttamente online ( tramite il tool ) ed installare la image nello slot specifico dove vuoi installarla.
@gippo devi semplicemente leggere le istruzioni per usare il package, che seguono dopo le indicazioni per installare la image base.
mi spiace, ma da qui non riesco a far nulla... mi sa che ho bisogno un istruzione passo passo....
@gippo ma sono descritte passo passo , non capisco....ti riporto le istruzioni che leggi nel primo post ( o laddove scarichi )
GIUNTI A QUESTO PUNTO AVRETE IL VOSTRO DECODER FLASHATO CON IL SOFTWARE BASE MA NON CONFIGURATO CON LA SCHERMATA CLASSICA (wizard-configurazione), PROCEDETE ALLA RAPIDA CONFIGURAZIONE BASE TRAMITE TELECOMANDO, PER ARRIVARE AL MENU DI SISTEMA E POTER ASSEGNARE UNA PASSWORD DI ACCESSO CHE RISULTA ESSERE INDISPENSABILE PER UTILIZZARE SIA FTPclient CHE LA CONSOLLE Telnet ( MENU-IMPOSTAZIONI-SISTEMA-RETE >> Impostazione Password )
ASSEGNATA LA PASSWORD SEGUITE LE SEGUENTI ISTRUZIONI INSTALLANDO IL PACCHETTO IPK CHE TROVERETE DENTRO IL FILE RAR SCARICATO DAL NOSTRO SITO. INSTALLAZIONE DA ESEGUIRE ESCLUSIVAMENTE CON INTERFACCIA TELNET-putty ( LINK putty )( si veda shot sottostante )
1) RIMUOVETE LA PENNETTA USB per evitare al riavvio un nuovo flashing.Inserite il pacchetto IPK tramite FTP in "/tmp/"
2) su telnet digitate il seguente comando (NON INSTALLARE TRAMITE IPK-INSTALLER DELLA IMAGE!)
Quindi ricapitolando :
1) assegna password ad openATV
2) scompatta package e metti il file APK in cartella /tmp/
3) manda comando telnet di installazione ( come indicato sopra )
@gippo è una cartella di sistema operativo enigma2, dentro il decoder la trovi accedendo via FTPclient ( Filezilla e/o WinSCP ) ma dico se ti dedichi a leggere 5minuti si capisce , è scritto "Inserite il pacchetto IPK tramite FTP in "/tmp/" , quando si dice via FTP si intende appunto quello che scrivevo prima, non hai mai usato FTPclient con enigma2 ?
@gippo buongiorno, molto strano perchè la scelta del decoder enigma2 è quasi scontato l'uso di FTPclient e Telnet , ma poco male se vuoi recuperare queste informazioni abbiamo una intera sezione dedicata alla crescita tecnica dell'utente:
nello specifico pui trovare utili queste sottosezioni :
GUIDE e primi passi nel mondo Enigma2 per utente Newbie
GUIDE e Problematiche Enigma2 - Tecniche e Procedure utente avanzato
Se non hai chiaro come usare FTPclient ( che sia WinSCP o Filezilla ) e Telnet chiedi pure cosa non capisci che ti rispondo in merito. :party:
forse stò cominciando a capire... con win scp mi sembra più facile ... metto host name ( mio ip) root ed mi si apre una cartella dove digitando root come password vedo le cartelle del decoder nella parte destra...apro la cartella tmp ...prendo il file ipk e lo trascino nella cartella tmp....
a questo punto...chiudo il programma, e vado su telnet?
@gippo si esattamente, hai capito tutto perfettamente, però ti consiglio di assegnare una password come prima cosa da fare:
Per motivi di sicurezza del tuo decoder e per poi poter usare il package perchè è impostato con password attiva per cui o prima o dopo dovrai senza dubbio assegnarla.
La password sarà utile sia a collegarti a WinSCP sia su telnet ( root/password)
una cosa che non capisco... quando entro ed assegno la password.... se esco e rientro nel menù rete-password non la vedo... è normale o non riesco a salvarla?
Ha scritto dopo 57 secondi:
