Nome: [IMAGE] ZGEMMA H5 Nemoxyz SATtek Premium FHD v7.4 - Py3 branch OE5.4
Autore: Nemoxyz
Descrizione: https://i.imgur.com/WRJ88wQ.png
VERSIONE SOFTWARE & SORGENTE
SATtekBUILD v7.4 Py3 Compiled - dedicated OEAlliance Feeds - Branch OE 5.4
BASATA SULLE RECIPES DELLA openATV 7.4 (si ringraziano i coders della ATV)
Skin SATtek-PremiumFHD v3.0 (mod by NemoxyzDesign):
BASATA sulla skin originale Premium-FHD-Magenta skin by MNASR (si ringrazia l'autore)
OFFICIAL-IMAGE-SATtechnology: Ver1 - 14-GIUGNO-2024
DISPOSITIVO
Adatto ad un decoder Enigma2 ZGEMMA H5 H265ready ( CPU MIPS )
https://i.imgur.com/tNrKSld.png
SATtek P r e m i u m - FHD v 7 . 4 Py3
https://i.imgur.com/BW7EoRj.png
" ...A STEAMPUNK TOUCH FOR ENIGMA2... "
Immagine Ufficiale SATtechnology Premium-FHD
FEATURES:
- Bootlogo SATtek Premium-FHD ( Nemoxyz design )
- SPINNER Technology POWER
- GSTREAMER ultima versione integrato di base + ServiceApp Player installato con default ExtePlayer3/GSTplayer/FFmpeg
- WEATHER OE PLUGIN - IMPOSTAZIONE LOCALITA'
- VISUALIZZAZIONE POSTER-LOCANDINE: suggeriamo uso di una usb/hdd per lo storage delle images
- Suggeriamo installazione del plugin per lista canali aggiornati: isettingE2 - VERSIONE Python3
LINK TOPIC UFFICIALE ED INFO:
SCREENSHOTS DI PRESENTAZIONE SATtek Premium-FHD v7.4 OEAlliance:
INSTALLAZIONE
Eseguire il seguente comando:
1) Dopo aver installato il plugin ( lo trovate in download su www.isettinge2.com oppure direttamente dai feeds della image )
Guida MOUNT USB DEVICE & XpiconS ( SAT+DTT+FREEiptv completi originali by Nemoxyz )
PICON SAT + DTT ITA
ZpiconS [417x250] HB13° + DTT Nemoxyz DESIGN (01-Novembre-2024) - HD & FullHD skin
X(small)piconS [100x60] HB13° + DTT Nemoxyz DESIGN (01-Novembre-2024)
ASTRA 19.2°E
ZpiconS [417x250] ASTRA 19.2° UPDATE (04 NOVEMBRE 2024) - HD & FullHD skin
X(small)piconS [100x60] ASTRA 19.2° UPDATE (04 NOVEMBRE 2024)
EUTELSAT 5°W + 9°E
ZpiconS [417x250] 5W° + 9E° EUTELSAT Nemoxyz DESIGN (06-Novembre-2024) - HD & FullHD skin
X(small)piconS [100x60] 5W° + 9E° EUTELSAT Nemoxyz DESIGN (06-Novembre-2024)
FREE-IPTV-RAKUTEN-PLUTO-TV
ZpiconS [417x250] Rakuten-Pluto-SamsungTV Nemoxyz DESIGN (20-Luglio) - HD & FullHD skin
X(small)piconS [100x60] Rakuten-Pluto-SamsungTV Nemoxyz DESIGN (20-Luglio)
Versione: SATtekBUILD-Ver1 [14-06-2024]
File: SATtekPremiumFHD-7.4-zgemmah5-20240614_usb.zip
Dimensione: 138.24 MB
Vedi Download: [IMAGE] ZGEMMA H5 Nemoxyz SATtek Premium FHD v7.4 - Py3 branch OE5.4
salve ho messo questa immagine sul mio zetagemma h5 ma ho notato che nella lista plugin si attiva per poco il tasto giallo per scaricare i nuovi plugin e non li scarica,poi i feed con e2isetting non li trova qualcuno ha provato questa immagine
@maurito3570 buongiorno, effettuo un controllo e ti faccio sapere in tempi brevi. A presto.
NB: esiste appositamente il topic ufficiale per effettuare discussioni, domande e richieste sulla image in questione non serve scrivere in un ulteriore topic, spostato post nella sezione adeguata.
@maurito3570 appena concluso controllo tutto funziona perfettamente come puoi vedere negli shot a seguire ( il tasto giallo non è corretto !!! )
1) browser plugin tasto verde
2 ) installa plugin tasto verde ( questo è corretto!! )
( in qst caso ho installato isettinE2 start per installare plugin isettingE2 per avere liste canali aggiornate )
3) plugin isettingE2 tutto perfettamente funzionante.
dopo la prima installazione è necessario eseguire un riavvio GUI ( o completo come desideri ) al fine di attivare i feeds della image e completare installazione.
@maurito3570 di quale sezione "giusta" parli non ho ben capito....i canali satellite sono criptati se non usi una Tivusat Card ovviamente non si vedono ( non ci entrano nulla i feeds quelli servono per accedere al repository per installazione estensioni e plugins OEalliance ). Inoltre consiglio di installare un setting adeguato per il tuo impianto satellitare di che impianto si tratta ? Hai impostato il tuner correttamente per il tuo impianto ? Impostazione - ricezione servizi - configurazione tuner ( di base è impostato con Hotbird 13 mono )
grazie ho risolto dovevo mettere i miei dati di registrazione a e2setting cosi ho poteto scaricare i canali giusti con i feed e configurare l'impianto satellite su scr ,cosi ho visione dei canali satelliti in chiaro,naturalmete i criptati non avento una tv sat non si vedono,in confidenza anche se so che non si puo,ma scaricare dai plugin una vecchia **** non lo trovata non c'è piu la sezione dove scaricarla dai plugin?
@maurito3570 come dico a tutti gli utenti...se solo dedicaste 5minuti di lettura delle descrizioni e guide di cosa scaricate avreste meno problemi. :laugh:
Nelle descrizioni ci sta scritto come fare per aggiungere il secret feed per quello che ti necessita.
ciao ho installato il secret feed con putty dice installato correttamente riavviato decoder ma il menu non lo trovo nella lista
@maurito3570 ciao, trovi tutto da tasto verde, tasto verde ancora una volta e fra le extensions scaricabili ed installabili trovi la voce che interessa a te. Poi da tasto blu puoi gestire il tutto.
