Sezione dedicata ai decoder GigaBlue UHD QUAD 4K
Nome: [IMAGE] GIGABLUE QUAD 4K Nemoxyz SATtek Brown AGLARE-FHD v7.5.1 - Py3 branch OE5.5.1
Autore: Nemoxyz
Descrizione: https://i.gyazo.com/13e2e36e053b54087890a18e59c5be28.png
VERSIONE SOFTWARE & SORGENTE
SATtekBUILD v7.5.1 Py3 Compiled - dedicated OEAlliance Feeds - Branch OE 5.5.1
BASATA SULLE RECIPES DELLA openATV 7.5.1 (si ringraziano i coders della ATV)
Skin SATtek Brown AGLARE-FHD v7.5.1 (mod by NemoxyzDesign):
BASATA sulla skin originale Aglare-FHD skin by MNASR (si ringrazia l'autore)
OFFICIAL-IMAGE-SATtechnology: Ver1 - 25-MARZO-2024
DISPOSITIVO
Adatto ad un decoder Enigma2 GIGABLUE QUAD 4K ( CPU ARM )
https://i.imgur.com/Kpe3avO.png
SATtek B r o w n AGLARE-FHD v 7 . 5 . 1 Py3
https://i.gyazo.com/638be132938e59960094c34ef15a6b99.png
" ...AGLARING THE FUTURE ON ENIGMA2... "
Immagine Ufficiale SATtechnology Brown AGLARE-FHD
FEATURES:
- Bootlogo SATtek Brown AGLARE-FHD ( Nemoxyz design )
- SPINNER Technology POWER
- GSTREAMER ultima versione integrato di base + ServiceApp Player installato con default ExtePlayer3/GSTplayer/FFmpeg
- XLASS VOD & LIVE Player IPTV
dettagli & approfondimenti:
X-Klass plugin - Xtream Codes IPTV Player ( by KiddaC ) [PLUGIN UNIFICATO X-Streamity]
- WEATHER OE PLUGIN - IMPOSTAZIONE LOCALITA'
- VISUALIZZAZIONE POSTER-LOCANDINE: suggeriamo uso di una usb/hdd per lo storage delle images
SCREENSHOTS DI PRESENTAZIONE SATtek Brown AGLARE-FHD v7.5.1 OEAlliance:
https://i.imgur.com/o4qOQFM.jpg
https://i.imgur.com/znjXt5B.jpg
https://i.imgur.com/t84ZRJN.jpg
https://i.imgur.com/v6JlDmM.jpg
https://i.imgur.com/iTe2IEv.jpg
https://i.imgur.com/S1uecRx.jpg
https://i.imgur.com/uuHq1f7.jpg
https://i.imgur.com/o21CUTK.jpg
https://i.imgur.com/PeZFrmk.jpg
https://i.imgur.com/MDQtMzV.jpg
https://i.imgur.com/xjuWpvo.jpg
https://i.imgur.com/HRfdngc.jpg
https://i.imgur.com/iGjb4Um.jpg
https://i.imgur.com/tTL8YiQ.jpg
https://i.imgur.com/mmD8b6b.jpg
https://i.imgur.com/VbTSlXK.jpg
https://i.imgur.com/LAEqht9.png
INSTALLAZIONE
Eseguire il seguente comando:
1) Dopo aver installato il plugin ( lo trovate in download su www.isettinge2.com oppure direttamente dai feeds della image )
Guida MOUNT USB DEVICE & XpiconS ( SAT+DTT+FREEiptv completi originali by Nemoxyz )
PICON SAT + DTT ITA
ASTRA 19.2°E
EUTELSAT 5°W + 9°E
FREE-IPTV-RAKUTEN-PLUTO-TV
ZpiconS [417x250] Rakuten-Pluto-SamsungTV Nemoxyz DESIGN (19-Maggio-2026) - HD & FullHD skin
X(small)piconS [100x60] Rakuten-Pluto-SamsungTV Nemoxyz DESIGN (19-Maggio-2026)
Versione: SATtekBUILD-Ver1 [25-03-2025]
File: SATtekBrownAGLAREFHD-7.5.1-gbquad4k-20250325_usb.zip
Dimensione: 142.82 MB
Vedi Download: [IMAGE] GIGABLUE QUAD 4K Nemoxyz SATtek Brown AGLARE-FHD v7.5.1 - Py3 branch OE5.5.1
Buona serata a tutti, qualche possessore di quad 4k è riuscito ad installare questo backup, grazie. A me legge la penna usb ma non parte con l’installazione, boh!
@gioca68 buonasera spiega meglio la procedura che utilizzi, scompatti la cartella, metti in usb e poi da decoder spento avvii con penna inserita e software al suo interno ? Se si cosa vedi sul decoder cosa accade. Dai maggiori dettagli altrimenti è difficile poter comprendere cosa non va, se il software o se dipende da altro.
allora, scompatto la cartella gigablue completa su una penna usb, da spento avvio con il tasto dietro il box mi dice di premere entro 10 secondi e rimane fermo con led rosso, ho reinstallato la release precedente ed è andato tutto liscio, non ha fatto una piega, boh! ho provato con altri firmware, con alcuni andava tranquillo con altri no, tipo con open atv 7.5.1 è andato con il 7.6.0 stessa suonata si blocca, con open bh 5.1.010 è andato ma non è stato installato perfettamente infatti dopo installato si bloccava all'avvio. mah!
@gioca68 probabilmente ho capito cosa accade e dipende quasi sicuramente dalla flash rom del tuo dispositivo in relazione al software utilizzato potrebbe non essere adeguata per versioni superiori ( forse per spazio insufficiente ). Purtroppo le images sono software compilati in modo nightly per cui senza test preventivo ( tutte le images engima2 sono così anche perchè sarebbe impossibile testare tutto bisognerebbe avere 1000 e più dispositivi a disposizione ).
La ATV 7.6 è ultima uscita e potrebbe essere troppo recente per questo modello così come le altre per gli stessi motivi.
Puoi fare questa prova, dalla release SATtekPremiumFHD-7.4-gbquad4k preleva i files indicati: kernel.bin e rescue.bin sostituiscili nella cartella che hai scompattato della nuova image ( questa nel cui topic stiamo discutendo ) SATtekBrownAGLAREFHD-7.5.1-gbquad4k poi riprova il flash e vediamo se va in porto ( diffido che possa essere valido come tentativo ma se vuoi provare). Se non va va fatta un'analisi più profonda in sede di compilazione ed eliminare qualcosa per ridurre lo spazio occupato....ma è un processo lungo e non è detto che sia risolutivo. Ad ogni modo la SATtekPremiumFHD-7.4-gbquad4k se va bene è un ottima image per cui non me ne preoccuperei.
Il problema sta proprio lì ATV 7.5.1 base o la SATtekPremiumFHD hanno una root compilata ( circa 124/126mb ) inveriore ai 128 MB ( limite fisico del GB Quad 4K in rom ) mentre la AGLARE o le altre che hai provato con esito negativo sono venuta purtroppo di qualche mega in più che impedisce il regolare funzionamento.
Ciao a tutti, ho provato ad installare questa release sul mio GigaBlue UHD QUAD 4k PRO, ma non funziona.
Ho controllato in OpenATV e mi sono accorto che il "PRO" è un modello diverso (più aggiornato).
@Nemoxyz : avete in programma di inserire una release di questa versione anche per GigaBlue UHD QUAD 4k "PRO"?
Grazie mille
@Josep buonasera purtroppo no questa release e questa compilazione non è più dispinibile per altri modelli oltre a queli realizzati ( si è conclusa nella primavera del 2025 ) , la interstellar invece è possibile realizzarla essendo release continuativa. Saluti ed auguri di buone feste.
