Sezione dedicata ai decoder Hitube 4K Combo
Nome: [IMAGE] HITUBE 4K PLUS Nemoxyz SATtek Brown AGLARE-FHD v7.5.1 - Py3 branch OE5.5.1
Autore: Nemoxyz
Descrizione: https://i.gyazo.com/13e2e36e053b54087890a18e59c5be28.png
VERSIONE SOFTWARE & SORGENTE
SATtekBUILD v7.5.1 Py3 Compiled - dedicated OEAlliance Feeds - Branch OE 5.5.1
BASATA SULLE RECIPES DELLA openATV 7.5.1 (si ringraziano i coders della ATV)
Skin SATtek Brown AGLARE-FHD v7.5.1 (mod by NemoxyzDesign):
BASATA sulla skin originale Aglare-FHD skin by MNASR (si ringrazia l'autore)
OFFICIAL-IMAGE-SATtechnology: Ver1 - 27-MARZO-2024
DISPOSITIVO
Adatto ad un decoder Enigma2 HITUBE 4K PLUS ( CPU ARM)
https://i.imgur.com/qdHyPXB.png
SATtek B r o w n AGLARE-FHD v 7 . 5 . 1 Py3
https://i.gyazo.com/638be132938e59960094c34ef15a6b99.png
" ...AGLARING THE FUTURE ON ENIGMA2... "
Immagine Ufficiale SATtechnology Brown AGLARE-FHD
FEATURES:
- Bootlogo SATtek Brown AGLARE-FHD ( Nemoxyz design )
- SPINNER Technology POWER
- GSTREAMER ultima versione integrato di base + ServiceApp Player installato con default ExtePlayer3/GSTplayer/FFmpeg
- XLASS VOD & LIVE Player IPTV
dettagli & approfondimenti:
X-Klass plugin - Xtream Codes IPTV Player ( by KiddaC ) [PLUGIN UNIFICATO X-Streamity]
- WEATHER OE PLUGIN - IMPOSTAZIONE LOCALITA'
- VISUALIZZAZIONE POSTER-LOCANDINE: suggeriamo uso di una usb/hdd per lo storage delle images
SCREENSHOTS DI PRESENTAZIONE SATtek Brown AGLARE-FHD v7.5.1 OEAlliance:
https://i.imgur.com/o4qOQFM.jpg
https://i.imgur.com/znjXt5B.jpg
https://i.imgur.com/t84ZRJN.jpg
https://i.imgur.com/v6JlDmM.jpg
https://i.imgur.com/iTe2IEv.jpg
https://i.imgur.com/S1uecRx.jpg
https://i.imgur.com/uuHq1f7.jpg
https://i.imgur.com/o21CUTK.jpg
https://i.imgur.com/PeZFrmk.jpg
https://i.imgur.com/MDQtMzV.jpg
https://i.imgur.com/xjuWpvo.jpg
https://i.imgur.com/HRfdngc.jpg
https://i.imgur.com/iGjb4Um.jpg
https://i.imgur.com/tTL8YiQ.jpg
https://i.imgur.com/mmD8b6b.jpg
https://i.imgur.com/VbTSlXK.jpg
https://i.imgur.com/LAEqht9.png
INSTALLAZIONE
Eseguire il seguente comando:
1) Dopo aver installato il plugin ( lo trovate in download su www.isettinge2.com oppure direttamente dai feeds della image )
Guida MOUNT USB DEVICE & XpiconS ( SAT+DTT+FREEiptv completi originali by Nemoxyz )
PICON SAT + DTT ITA
ZpiconS [417x250] HB13° + DTT Nemoxyz DESIGN (01-Novembre-2024) - HD & FullHD skin
X(small)piconS [100x60] HB13° + DTT Nemoxyz DESIGN (01-Novembre-2024)
ASTRA 19.2°E
ZpiconS [417x250] ASTRA 19.2° UPDATE (04 NOVEMBRE 2024) - HD & FullHD skin
X(small)piconS [100x60] ASTRA 19.2° UPDATE (04 NOVEMBRE 2024)
EUTELSAT 5°W + 9°E
ZpiconS [417x250] 5W° + 9E° EUTELSAT Nemoxyz DESIGN (06-Novembre-2024) - HD & FullHD skin
X(small)piconS [100x60] 5W° + 9E° EUTELSAT Nemoxyz DESIGN (06-Novembre-2024)
FREE-IPTV-RAKUTEN-PLUTO-TV
ZpiconS [417x250] Rakuten-Pluto-SamsungTV Nemoxyz DESIGN (20-Luglio) - HD & FullHD skin
X(small)piconS [100x60] Rakuten-Pluto-SamsungTV Nemoxyz DESIGN (20-Luglio)
Versione: SATtekBUILD-Ver1 [27-03-2025]
File: SATtekBrownAGLAREFHD-7.5.1-hitube4kplus-20250327_mmc.zip
Dimensione: 134.8 MB
Vedi Download: [IMAGE] HITUBE 4K PLUS Nemoxyz SATtek Brown AGLARE-FHD v7.5.1 - Py3 branch OE5.5.1
